T-Mobile HD2 English Discussion Thread
nedcom
hi to all
dose any one knows how to lock the screen while call is in process (in hd2)..?
while call is in process, the hair or my ears i don't know.. but something starts to zoom and change the screen, maybe open another program, the screen must lock while i receive or send calls in order not to touch and open any program accidentally by the hair or any part of the face.
thanks to all
g.romano81
*lol* still the same Phone as before with new Windows Phone Cover!
in Attachment you will find Dual SIM SPB Patch for WVGA Phones like this T-Mobile or MTK HD2!
This version of Dual sim SPB mobile shell with Mobile sense have 2 problems for me:
- The Carousel doesn't work
- 3D message and email view doesn't work
Do you have any solutions?
Petteri
No, because thats an older SPB Version Patch....soinstall only when DUAL SIM is needet in SPB....i use 3.5.5 normal and do call from WM!
Full Battery
The English ROM V3 doesn't ask when sending a message which Sim to use to send a message
do u have a solution?
or any other messaging software that can handle dual sim?
LowMan
Strange. I am using the version that was posted here (installed clean after hard reset).
Carousell works, 3D message view works for me. I am using V3 newScreen ROM and everything works perfectly.
Please check what You have installed and try to install on clean ROM.
regards
LowMan
nedcom
hi guys....
dose anyone knows a 3d photo viewer which can works with SBP, ust like the one which comes with touchflo 3d ?
thanks
cph777
Hi all,
has anyone else the issue with the camera that all photos have no red at all? photos look like a green filter is applied. Any known solution on this ?
thanks
petertrol
Hi! i think everybody has the same problem with camera. i think its matter of software version or something. Anybody has improved the camera settings??
g.romano81
I can't download HD2 Multitouch "NEW SCREEN" FW V3 English
To Petteri:
There are problems with the download of
Can someone help me?
sathelp
Quickmark or QR Code reader
Hi
Has anyone managed to get the Quickmark Bar code reader to work with the camera in the clone HD2? I have tried but have problems with this and other bar code readers. Any help appreciated to find a solution to read bar codes especially the QR type.
Thanks
nedcom
hi everybody,
M E R R Y C H R I S T M A S.....
has anyone know a 3d photo viewer (just like the on in Touchflo) to install it on t-mobile.
thank you
g.romano81
I have solved my problems to download this ROM "HD2 Multitouch "NEW SCREEN" FW V3 English"
Now I would like to try it but first I would like to know if it is really working with multi-touch applications.
Which multi-touch software work with this ROM?
Thank you very much to everybody
HAPPY CHRISTMAS
HAPPY NEW YEAR
Petteri
i think multitouch only works on picture Galleries! Not on browsers like Opera......i will get latest T-Mobile next days, so i will test again!
g.romano81
Wifi remote access on Dual Sim T-Mobile HD2
I have some problem when using Wifi remote Access on my Dual sim T-mobile HD2.
It's easy to use this program but when I digit my IP address on my PC browser it doesn't reach the device.
Could someone help me?
P.S. What about the new ROM? Is it ready?
ddlewis
@benajamin: friend, do you know how much work it is?! OK, i will do it next days...but not today! :)
@petertrol: the ROM i have you`ll find here in Our Downloadbase: http://chinamobiles.org/downloads.php?do=file&id=401
Use instruction HERE.....not the instruction inside the Downloaded ROM Upgrade!!! Very important!!!!
The UI is: SPB MobileShell 3.5.5 and naongs MobileSense (find at xda-developers) is changing to spanish! No Problem! :)
Where can I get out (download) program
'SP_EndUser_Download_Tool_exe_v1.0940.0' ?
