Jiayu S2 Octa-Core 1.7GHz MTK6592, 5" FHD/OGS Gorilla 2 Screen / Narrow Bezel
s7yler
Youtube.com/s7yler
Jiayu S2 Octa-Core 1.7GHz MTK6592, 5 Inch FHD/OGS Gorilla 2 Screen / Narrow Bezel
Das Jiayu S2 (2GB RAM/32GB ROM Variante) hab ich bei Coolicool.com hier bestellt
http://de.coolicool.com/jiayu-s2-mtk6592-17ghz-octa-core-50-zoll-fhd-ogs-display-android-42-3g-smartphone-g-283212
UNBOXING VIDEO, UND QUICK TEST
Vollständigen TEST
Notification LED Test (3 Farben)
Highlights
- 6mm ultrathin body / 2.3mm bezel
- Stainless steel metal frame
- 5 inch IPS Screen, 1920*1080 pixel display
- Corning II Gorilla Glass / PPI 440
- MT6592 1.7GHz Octa core
- Cortex-A7 cores, integrated Mali-450 MP4 700MHZ
- Support 3G, GSM 900/1800 & WCDMA 2100 MHz
- 2 GB RAM + 32GB ROM
- Nofification LEDs (3 colors)
- Camera 13MP Panasonic CMOS back + 8MP front Sony
- F2.2 large aperture wide-angle lens
- Air gestures (both directions) in gallery, browser, contacts, desktop, music player
- Support desktop & lockscreen themes
- Support widgets on lockscreen
- Support "Clearmotion" Video Fluency Enhancer
- Support Miracast, GPS, Bluetooth, OTG, MHL
- Supports call recording (record your call, works fine)
- Dropzone multitasking box
- Dual Micro SIM card
- Dimensions (W×D×H): 139 x 67.6 x 6mm
- AnTuTu: 25-26000
- Original battery: 2000 mAh (of a fair/good quality)
- Comes pre-rooted, enable ROOT in phone settings
ROMs:
http://www.needrom.com/mobile/jiayu-s2/
Kann das officielle JIAYU S2 - FL - Update 05/30/2014 (S2 20140530-204210) sehr gut emphlen! Sehr schnell und mit alle apps 100% stabiler ROM.
MIUI V5 4.5.30 Port
http://www.needrom.com/mobile/jiayu-s2-2/
Kamera Bilder/Test
http://peecee.dk/uploads/052014/IMG_20140525_143338.jpg
http://peecee.dk/uploads/052014/IMG_20140524_124232.jpg
http://peecee.dk/uploads/052014/IMG_20140525_143319.jpg
http://peecee.dk/uploads/052014/IMG_20140524_124257.jpg
http://peecee.dk/uploads/052014/IMG_20140525_143352.jpg
http://peecee.dk/uploads/052014/IMG_20140524_124804.jpg
http://peecee.dk/uploads/052014/IMG_20140524_124527.jpg
Original picture http://peecee.dk/uploads/052014/DSC04390.JPG
Original picture http://peecee.dk/uploads/052014/DSC04413.JPG
Original picture http://peecee.dk/uploads/052014/DSC04437.JPG
Original picture http://peecee.dk/uploads/052014/DSC04435.JPG
Original picture http://peecee.dk/uploads/052014/S1410010.JPG
Original picture http://peecee.dk/uploads/052014/S1410001.JPG
JensK
@s7yler, kleiner Tip: stelle mal in der Kamera den Weissabgleich auf Neonlicht, dann ist der graessliche Sepiaeffekt (Schweinchenrosa) weg, den einige Kameraimplementierungen (bei Mediatek Geraeten) unter kuenstlichem Licht zeigen. Meine beiden Zopos hatten das gleiche Problem, beim THL T100 ist es gluecklicherweise nicht so.
s7yler
Youtube.com/s7yler
Ok danke für den Tip
Stani69
Hallo !!! Hat schon jemand Erfahrungen mit dem Jiayu S2 gemacht und weiß jemand ob es dieses in Schwarz geben wird ??? MFG
s7yler
Youtube.com/s7yler
Ja ich habe Erfahrungen :) sollte auch in schwarz kommen, aber wann wissen selbst der Jiayu support nicht. Bis jetzt nur in weiss erhältlich.
Jovise
Hey S7yler, hat Jiayu S2 notification-leds? Wenn ja, welche Farben? Kann man light flow installieren?
Wie lange hält Akku?
Danke im Voraus
VLG Jovise
haytapot
ich besitze seit 4-5 Wochen S2.
Akku hält locker einen Tag. bei mir hält es 2 Tage.
wenig telefonieren nur Datenverbindung um Mails zu lesen.
notification-led nur in 3 Farben: Grün, Blau und Rot, mit apps kann man einstellen.
Stani69
Wo hast du das Handy gekauft und wieviel hast du bezahlt ??? Bist du zufrieden und würdest du das Handy empfehlen , es gibt ja noch keine Testberichte ???
haytapot
ich habe von Aliexpress gekauft, mit eust und DHL 265€, mittlerweile günstiger geworden.
bis jetzt bin ich zufrieden, 2 Mankos habe bis jetzt entdekt.
1-Akku wird nie bis 100% aufgeladen.
2-GPS-Fix dauert länger als gedacht und maximal 5meter Genauigkeit.
um GPS zu verbessern gibt es Möglichkeiten die ich noch nicht getestet habe.
ansosnten funktioniert problemlos, keine Netzabbrüche wie bei manchen G5.
s7yler
Youtube.com/s7yler
Das ist komisch, meiner geht immer bis 100% beim laden.
Der Test (aber in Englisch) ist im Video im #1 kannst du den nicht sehen?
www.youtube.com/watch?v=sPME2A0_KeQ
Hab es von hier http://de.coolicool.com/jiayu-s2-mtk6592-17ghz-octa-core-50-zoll-fhd-ogs-display-android-42-3g-smartphone-g-283212
Ich kann das Handy 100% weiterempfehlen!
Jovise
HUAWEI P7-L00 (Akku 2500mAH, GPS Glonass und Kamera sehr gut, die Meist Huawei aus China Unicom ROM sehr schlecht). JIAYU S2 (Kamera toll, Akku nur 2000mAH, anscheinend GPS schwach).
Hmmmm, was soll ich nehmen???
Habe im Moment Huawei P6S, Kamera und GPS TIP TOP, ROM schrott!!!
s7yler
Youtube.com/s7yler
Also, der GPS ist im Auto bei mir ganz gut, wie man hier auch sehen kann
GPS test im Video bei 15:57
www.youtube.com/watch?v=sPME2A0_KeQ#t=15m57s
uniunitracking
