FOG N4, Advanced S-Pen, MTK6592 1.7GHz, 5.7" IPS HD OGS, IR Sensor, OTG, 4D Air Gestures, Heart rate
s7yler
Youtube.com/s7yler
Unboxing
Full Review
Von hier: http://efox-shop.com/fog-n4-mtk6592-17ghz-octa-core-57-zoll-hd-bildschirm-android-44-3g-smartphone-g-298380
INDEX/Video Review Inhalt:
Specifications
Phone design
2.5D curved glass design
Lockscreen
The User Interface / Launcher
UI scroll speed
Viewing angles
Some words about the screen
The hardware buttons with backlight
Offscreen gestures & double tap to wake
4D air gestures
The quick toggles
Wifi signal & network reception, 3G
The sidepanel
Multitasking overview in Lollipop style
Multiwindow sidebar (not real multiwindow)
The FOG N4 compared with the Landvo L600S
The settings
Language
Storage
About phone, android version & wireless update?
Camera app
Camera test
Frontfacing camera test
Flashlight LED test
S-health app, Heart rate app test
ZaZa remote IR blaster app
Videoplayer & popout feature
Advanced S-pen test
USB OTG test
Music test over Bluetooth (with OTG, USB stick)
Music test with internal phone speaker
Info about using headphones with the phone
Test call, sound & proximity sensor test
Test of original Note 4 battery & backcover
Running some different test apps!
WiFi & speedtest
Androbench read/write speedtest
GPS test results
Antutu benchmark v5.6.1 results
Sensors
Notification LED colour test
3D gaming racing test
Multitouch screen test, 10 points!
Root checker
Link2SD storage check
CPU Identifier info
Playstore, Browser & Youtube test
Check of phone weight, battery weight & phone thickness
Pros & Cons
Kamera Samples/Tests
( https://plus.google.com/photos/100582382505207418108/albums/6122864809660919697 )
IMG_20150223_175409.jpg IMG_20150223_175608.jpg IMG_20150223_180129.jpg IMG_20150223_180136.jpg IMG_20150223_180344.jpg IMG_20150223_180516.jpg IMG_20150223_180523.jpg IMG_20150223_180541.jpg IMG_20150223_223935.jpg IMG_20150223_224014.jpg IMG_20150223_224023.jpg IMG_20150223_224034.jpg IMG_20150223_224046.jpg IMG_20150305_101752.jpg
FOG = FOCUS ON GEEKS! :scratch_one-s_head:
Technische Daten:
- 5,7-Zoll-Bildschirm, 1280x720 Pixel IPS HD OGS (10 Point Multitouch Schirm!)
- MT6592 1,7 GHz Octa-Core
- Dual Mic Noise Reduction
- Dual Micro-SIM
- GSM 850/900/1800/1900MHz, WCDMA 850/1900/2100 MHz
- 1 GB RAM + 16 GB ROM
- 13 MP Hauptkamera + 5 MP Frontkamera (Kameras sind okay und brauchbar)
- Unterstützt Advanced S-Pen Features (ganz gut gemacht, der S-Pen ist aber nicht so schnell)
- CNC-Aluminium-Zink-Aluminium-Rahmen
- Android 4.4.2 KitKat-System
- IR-Fernbedienung (funktioniert sehr gut)
- Double Tap zu wecken
- Kopfhörer-Sound Qualität ist gut (aber nicht so laut!)
- 4D Air Gestures (alle 4 Richtungen)
- Herzfrequenz-Sensor (ich glaube fake!)
- OTG USB On The Go
- Notifikation LED (RGB) und Touchbuttons mit Hintergrundbeleuchtung
- Gorilla-Glas (Ich bin im Zweifel, ob es echt ist)
- Unterstützt auch drahtlose Aufladen (jedoch "Charger pad" NICHT im Lieferumfang enthalten!)
Cons:
- Verarbeitungsqualität nur wie die 1:1 Note 4 klone, wirkt billig!
- Nur HD Bildschirm, kleine Pixels kann man ganz nah erkennen!
- Der Helligkeit ist nicht 100% stabil auf mein FOG N4.
- Original Note 4 Akku passt nicht drin, Cover-Rückseite geht, aber die Kamera ist rund statt eckig!
- Sehr wenige Sensoren!
- 2 Akkus sind mit, aber die sind klein! wahrscheinlich nicht viel mehr als 1700-1800mAh Max! (wie die Klone)
- Nach meiner Persönlicher Meinung viel zu teuer!
Ich kann das FOG N4 aufgrund dieser von mir kritisierten Punkte, nur bedingt empfehlen!
s7yler's Bewertung ***** (2 von 5 Sternen)
Binser
Gibt's jetzt für 170 USD
http://www.geekbuying.com/item/FOG-N4-5-7-inch-IPS-HD-Screen-Android-4-4-MTK6592-Octa-Core-1-7GHz-Smartphone-1GB-16GB-13-0MP-5-0MP-3G-GPS---White-341110.html
Würdest Du es für diesen Preis jetzt empfehlen? Ich hatte den Eindruck, Du hast das Phone hauptsächlich wegen des Preises abgewertet.
Übrigens schreibst Du: "Dual Mic Noise Reduction". Hat es wirklich 2 Mics für Stereo Aufnahmen und funktioniert die Noise Reduction tatsächlich wenn man in lauten Umgebungen telefoniert?
Was für einen anderen Note 4 Klon würdest Du empfehlen (inkl. IR und S-Pen)?
s7yler
Youtube.com/s7yler
@Binser
Kenne leider keine Alternative mit IR und advanced S-pen. Naja ich finde es sollte 145 USD kosten, nicht viel mehr weil so vom Verarbeitungsqualität wirkt es ein bisschen Billig finde ich. Die Noise Reduction ist für mich schwer zu einschätzen, aber der Ton ist schon viel besser als bei mein Note 3 1:1 Klon. Aber nicht wie auf die teuren Brands.
Binser
Danke für Deine Antwort. Darf ich noch mal nachfragen:
"Wirkt" die Verarbeitungsqualität einfach nur billig (wegen dem Aussehen, den Materialien) , oder ist das Gerät tatsächlich schlecht verarbeitet, so dass die Funktionalität oder Haltbarkeit beeinträchtigt ist?
s7yler
Youtube.com/s7yler
Verarbeitung ist eigentlich ok, Wirkt aber billig wegen Aussehen und den Materialien.
Daemonarch
Chiclone-Lover
Weil, nach meinem "Gefühl" (vergleich im Media-Markt), wirkt der HDC-clone kaum weniger wertig als das Original.
Binser
Das 1 GB ROM ist schon ein bißchen schwach. Kann man den nicht umformatieren?
Ansonsten müßte man halt Link2SD oder Mounts2SD verwenden.
Daemonarch
Chiclone-Lover
Kann man, ist halt nicht komplett risikolos - gibt hier auch nen schönen Thread zu.
Wenn man ein funktionsfähiges Backup und/oder die Stockrom parat hat, ist es recht risikoarm.
Muss man sich halt akribisch einlesen.
uniunitracking
