testie
hast wohl recht:
Double tap to wake up Android Lollipop
This is a very simple feature Google has taken from third party handsets and made its own (though it is only available on some devices such as the Nexus 6 as it needs compliant hardware).
Marsz
Dieses double tap to wake up, kann nichts mit der Software zu tun haben.
Mein altes LG G2 hat Android 4 irgendwas drauf und hatte schon von Werk aus dies dabei.
Zum Bildschirm aufwecken und ausmachen muss mann nur zwei mal tippen.
Glaub LG war der Vorreiter dabei.
reflex_
Møňş†ę®
ist denn schon wieder Freitag.....gibt es ei neues Rom
Changelog:
[Phone]
Fix - Sometimes Internet calls could not be made in 2G network (11-10)
[Contacts]
Fix - Mi Cloud namecard contacts were not included in Mi Account contacts (11-11)
[Lockscreen, Status Bar, Notification Bar]
Optimization - No service icon in status bar (11-06)
Optimization - Lockscreen camera shortcut is hidden in Child mode (11-06)
Optimization - Support changing wallpaper from top right corner in lockscreen when daily lockscreen is enabled (11-09)
[Home screen]
Optimization - Icons' names shadow effect when using light colored wallpapers (11-09)
[Gallery]
Fix - Random FC error when scanning shared albums (11-10)
[Music]
Optimization - ‘Discover’ page updates online music resources more timely (11-10)
Optimization - Support choosing from several modes when playing with car bluetooth (11-10)
[Backup]
New - Added Transfer feature to help move data from an old Mi device to a new one (11-10)
[File Explorer]
New - Support adding folders to private folder (11-09)
New - Allow selecting restore path when disabling private settings (11-09)
[Video]
Fix - FC error (11-11)
Optimized options for Settings - Advanced Settings - Battery - Battery saver
Optimized Browser front page
Added Daily lockscreen changing interval
Download ROM: xiaomi.eu_multi_hermes_5.11.12_v7-5.0.zip
Bug report:
WLAN-Verbindung bricht ab nachdem das Display ausgeht, auch bei der China ROM.
reflex_
Møňş†ę®
Ja.
Der BUG wurde gemeldet, aber noch nicht bestätigt.
@testie
Double 2 Wake ist vom Kernel abhängig, und nicht von der Android Version.
Da leider immer noch nicht der komplette Source Code veröffentlicht wurde kann sich auch kein Modder an den Kernel ranmachen. In den nächsten Wochen kommen ja noch neue Phones wo vermehrt der X10 zum Einsatz kommt, evtl. besteht da Hoffnung.
Sichern und Wiederherstellen von Einstellungen:
Hallo, ich bin ein totaler MIUI-Frischling und freue mich über die wöchentlichen Updates. Installiert ihr die ohne Werksreset einfach drauf? Ich hatte gehofft, dass ich meine Apps, Einstellungen und Optik meines Startbildschirms in die Mi-Cloud sichern und nach einem Werksreset und Neuinstallation einfach wiederherstellen kann. Das habe ich bisher noch nicht hinbekommen. Bisher habe ich das immer mit TitaniumBackup gemacht. Und wenn ich zB. den Nova-Launcher mit seinen Einstellungen mit TB gesichert hatte, hatte ich nach seiner Wiederherstellen meine gewohnten Startbildschirm wieder. Kann das nicht MIUI von sich aus?
J
johndebur
Ich mache das so wie du. Also mit Titanium backup.
In die MiUI bzw Google Drive CLoud Apps sichern, hatte zwar funktioniert, jedoch hatte ich dann Probleme mit einigen bezahlten Apps, die dann Lizenzprobleme bekommen hatten.
Oder es fehlten dann Einstellungen. Musste diese Apps dann deinstallieren und neu aus dem GOogle Play store installieren.
Insofern nutze ich diese Clouds, nur um WLAN Einstellungen, HAndy Einstellungen zu speichern.
Für Apps funktioniert für mich der Titanium backup einfach besser. Und Nova Launcher ist dann auch drauf :)
Allerdings bin ich jetzt auch nicht der Experte.
OK, Apps mit Titanium Backup, das ist ja auch recht einfach. Aber wie stelle ich die Handy-Einstellungen aus der mi-Cloud wieder her? Ich habe gestern ein Mi-Konto erstellt, es wurden automatisch einige Sachen in die Cloud hochgeladen (0,48GB / 5,0GB). Nun habe ich einen Werksreset gemacht und die aktuelle xiaomi.eu_multi_hermes_5.11.12_v7-5.0 installiert. Wie muss ich jetzt vorgehen, um alten Einstellungen wieder zu bekommen? Ich habe manuell Verbindung zum WLAN hergestellt und das Handy am Mi-Konto angemeldet. Wie stoße ich jetzt die Wiederherstellung meiner Einstellungen an?
J
johndebur
hmm also ich glaube in die Mi Cloud speichere ich die Einstellungen gar nicht. Bei mir wird auf Google Drive gespeichert.
Das wäre unter "Weitere Einstellungen" -> "Sichern & Zurücksetzen" -> Lokale Sicherung -> " backup anlegen" , kann man auch automatisch einstellen, aber ich mache das manuell immer bevor ich ein update installiere
Und da habe ich dann "System" (backup von den Systemeinstellungen und layout vom Homescreen ) und Account und Kontakte an. Mit bezahlten Apps hatte ich da schon meine Probleme, da nutze ich dann Titanium.
Poppeye
Changelog:
[Phone]
[Contacts]
[Home screen]
[Gallery]
[Music]
[Backup]
[File Explorer]
[Video]
Bug report:
Auch wieder laggy, kommt wieder runter.
Hat schon jemand die Deer-ROM getestet? Damit läuft auch Xposed!
http://forum.xda-developers.com/showthread.php?t=3224364
Guleru
ich schon wieder :(
nach jedem Reboot geht mein WSM mit dem Alarm Time Fix nicht mehr....mußte es deinstallieren.
Nun habe ich festgestellt, dass meine Kalendererinnerungen immer dann funktionieren, wenn die App im Hintergrund geöffnet ist. Sobald sie geschlossen wird, funktionieren die Erinnerungen nicht mehr :mda:
Gibt es in Miui 7 irgendwo eine Einstellung, dass die App im Hintergrund niemals geschlossen wird?
danmue
Die Taste unten links kurz drücken und die app nach unten ziehen. Dann ist ein Schloss davor, welches bedeutet, dass die app nicht mehr aus den speicher geworfen wird.
Dann unter: Sicherheit -> Rechte -> Autostart der App den Autostart erlauben
Danach unter: Einstellungen -> Weitere Einstellungen -> Akku -> Akkuverbrauch der Apps verwalten -> Apps auswählen -> Deine App -> Benutzerdefiniert auf: Verbunden bleiben stellen (falls sich die App im Hintergrund Daten aus den Netz holen muss)
Hilft übrigens auch bei WhatsApp ;)
@Guleru ich bezweifle ganz stark, daß Du überhaupt eine App dafür benötigst, der Hase liegt ganz sicher anderswo begraben. Was @danmue vorgeschlagen hat, auf jeden Fall mal umsetzten:
uniunitracking
