Nurnai
Just me
Die .eu basieren auf der China Rom. Das ist der Hauptunterschied. Manche Sachen fehlen in der Global die in der China enthalten sind, z.B. andere Schriftarten.
danmue
Gibt es einen echten Unterschied zwischen .eu und Global ?
Definitiv!
Auch die Übersetzung ist teilweise verschieden
Und das:
xiaomi.eu meinte:
Our ROMs features (Whats not in Global):
  • Based on China Stable / Weekly builds (except HMNote3SE)
  • Enabled search gesture (swipe up) on the desktop
  • Enabled MiDrive in File Explorer
  • Added landscape mode for SMS app
  • Sunrise/Sunset in the weather app
  • Google apps support integrated
  • Importing theme from zhuti.xiaomi.com via ThemeManager
  • No useless Chinese bloatware apps
  • More free RAM due to less background processes
  • Unified flat style app icons for both system and 3rd party apps (eg. Play Store icon flat too, unlike official global MIUI)
  • Advanced menu with color icons (not just text like in official MIUI releases)
  • No any Chinese character under the full system
  • Mi Video, Mi Music, Mi Radio, Mi Browser: No any useless Chinese content
  • No possibility to re-lock bootloader accidentally with flash any xiaomi.eu release
  • Added real 27 languages translation made by Official MIUI Fansites and MIUI Fans
  • Added EU T9 dialer support
  • Added charging sound switch
  • Added Spell Checker switch
  • Added Screen-OFF animation
  • Optimized GPS settings for EU
  • Optimized Battery consumption
  • Optimized RAM consumption
  • Added OIS auto-calibration for MI5
  • Added 4k Video support for MI4C, MI4S, HMNote3Pro, HMNote3SE, HMNote4X
  • Added 3D Touch to MI5S 3GB RAM version
  • Added GSMalphabet into SMS app
  • Added more icons grid layout 4x5, 4x6, 5x5, 5x6
  • Added Toggles 5x3 layout
  • SafetyNet passed (Android Pay)
  • Play Store Certified
  • Deodexed
  • Added automated tasks
  • Added game speed booster
  • Added erase module (magic elimination) to Gallery photo edit options
  • Fixed low volume sound via headphone
  • Fixed Google assistant voice response issue
  • And more, and more made by our 5 years MIUI mods experience..
meines Erachtens etwas aufgeräumter, ohne China- und diverse google-Apps.
bilde mir auch ein, etwas besser / mehr übersetzt.
habe das "aufwendige" umflashen bisher nicht bereut, auch wenn es nur ein Übergangsgerät ist ;)
derklotz
sorry wenn ich nochmal frage, bei mir werden im Kamera Ordner alle Bilder nach Datum untereinander sortiert.
Ist das normal wegen Miui oder Android 7, kann man das ändern das einfach alle Bilder aneinander kommen???
Wie lässt sich die Lautstärke von Klingelton und Benachrichtigung getrennt regeln?
L
Lucky 2
Lautstärke regeln vielleicht mit App Slider Widget - Lautstärken
Meinst du mit Kamera den Ordner.
Camera den man über Dateien-Speicher - bei mir jetzt SD Karte- DCIM- Camera erreicht.
Da kann man oben rechts auf die drei Punkte anders sortiert einstellen.
L
Lucky 2
Darum habe ich ja geschrieben mit der App
Slider Widget Lautstärken probieren.
Wer es braucht.
bzgl. Fotos: ich nutz noch immer (parallel) eine ältere gepatchte Version von QuickPic
derklotz
Wenn ich in Galerie gehe, dann oben Bilder/Alben auf Ordner Kamera oder andere.
Dort werden mir zB 5 Bilder von Heute angezeigt dann kommt ein weißer Balken mit Datum
dann kommen die nächsten Bilder usw.
Auf meinem alten waren dort einfach alle Bilder nacheinander ohne Datum Unterbrechung.
L
Lucky 2
Das kannst du nicht ändern.
Entweder andere App drauf oder einfach auf
Dateien - Kategorie ist voreingestellt dort auf Bilder
S.Oliver
An alle RN4 Global User mit MIUI 9.0.5.0 Stabil...
habt Ihr auch keine "Akku-Prozent-Anzeige" (%) in der Statusbar trotz angewählter Option in den Settings ???
Zur Info:
Ich habe seit Freitag ein Redmi Note 4 (x) global version 4 GB / 64 GB MIDO Model 2016102, mit dem updater auf MIUI 9.0.5.0(NCFMIEI) Stabil //Android 7.0 NRD90M gebracht, aber immer noch die Akku Prozentanzeige !
(Mi Thema ist Nebula Dark UI falls das eine Rolle spielt)
Gruesse S. Oliver (Umsteiger von INEW V3)
S.Oliver
Note 4 (x) global version: Unlock, TWRP, DM-verify, Lazyflasher, Root, Magisk, Safety Net, xiaomi.eu ROM
Ich habe mein Redmi Note 4 (x) global version 4 GB / 64 GB MIDO (EU Lager, DHL Versand aus Berlin Rüdersdorf für 144,48 EUR bei Ibuygou Digital.,LTD)
Model 2016102 (http://trendytechz.com/xiaomi-mi-2016102-clears-fcc/) noch keine 72h, möchte es aber danach entsperren, rooten und zudem evtl. ein Xiaomi-EU Rom nutzen.
CE; Band 20: 800 Mhz; VoLTE
Front Camera Samsung ofilm_s5k5e8
Back Camera Samsung ofilm_s5k3l8
LCD qcom, mdss_dsi_otm1911_fhd_video
TP Biel, FT5435, Ver.10
Fingerprint FPC
Build AL1512-mido-build-20171113213xxx
Baseband Ver 953_GEM_Pack-1.112222.1.1196701.1
Das Handy hat sich gestern 5.1.2018 mit dem Updater von MIUI 8 global stable auf MIUI 9.0.5.0(NCFMIEI)stable Android 7.0 NRD90M aktualisiert.
Bisher verstehe ich das so:
Die Mido's müssen nicht nur unlocked* werden, sondern die System Partition ist mit "DM-Verify" in "fstab.qcom" schreibgeschützt.
Wenn man mit ADB "fastboot flash recovery" das TWRP-Mido image aufspielt, muß man ein custom Rom flashen, was einen Kernel mitbringt, wo "dm-verity" in der "Fstab" auf disabled gesetzt ist.
Will man aber weiter ein Stock Rom nutzen, braucht man Lazyflasher, was den dm-verity Check bis zum nächsten booten bzw. flashen auf "Pass" setzt, damit man das Stock Rom über TWRP einspielen kann.
Man muß wohl auch das neue TWRP erstmal mit "fastboot reboot" neu starten, damit es nicht automatisch beim ersten Booten wieder entfernt wird ?
Angeblich kann man das Handy auch mit TWRP wipen um dm-verity dauerhaft zu entfernen ?
Ich möchte außerdem noch rooten und will diesmal Magisk statt SU nutzen, damit ich bestimmten Apps vorgaukeln kann, daß das Handy nicht gerootet ist und den SafetyNet Check bestehe.
Vermutlich kann man mit dem Xiaomi.EU Rom dann weiter automatisch mit dem Updater OTA ROM updates installieren, wie zur Zeit beim Stockrom (also ohne über TWRP zu gehen) ?
Kann mir jemand sagen ob ich das so richtig verstanden habe, damit ich nächste Woche nicht auch im Bootloop lande ?
(Habe die Frage auch im miui-germany.de Forum; beim INEW V3 war das mit CWM/SU einfacher)
Gruesse S. Oliver
*P.S. Falls beim Unlock Tool Antrag immer wieder eine chinesische Seite erscheint (http://en.miui.com/thread-444143-1-1.html), muß man nur einen neuen Nick Namen vergeben, also nicht den, den man ggf. im Account schon vergeben hat.
Mein RN4 hat sich ja mehr oder weniger selbstständig auf die globale stable 9.0.5.0 upgedatet. Als vorinstallierte Apps sind Gmail und diverse MS Office Produkte vorinstalliert. Während sich die Office Produkte bei Bedarf deinstallieren lassen würden, kann ich Gmail leider nicht deinstallieren. Auch eine Deaktivierung ist nicht möglich. Gmail verhält sich ein bisschen wie Bloarware.
Ich möchte gerne K9 für meine beiden Mailaccounts nutzen.
Leider meldet sich Gmail immer unaufgefordert von alleine, wenn eine Mail eingeht.
Ich möchte auch nicht den 2. Account über Gmail laufen lassen.
Hat einer von euch eine Idee?
Eigentlich wollte ich auch erstmal auf der Global stable bleiben.
kann man gmail evtl. deaktivieren in den Einstellungen ?
habe gerade nur eu-roms hier, da hab ich gmail gar nicht mehr ...
ansonsten die Benachrichtigungen für gmail komplett deaktivieren und evtl. auch das Abholen der Emails beeinflussen. gmail die Rechte für mobile Daten oder / und wlan entziehen ...
man kann doch (theoretisch) beliebig viele Email-Apps parallel installiert haben, die alle (per imap) auf die jeweiligen Datenbanken zugreifen. ich nutze auch nur K9 !!!
Beides läuft auch parallel, das ist nicht das Problem.
Unter Sicherheit - Datenverbrauch - Datenverkehr einschränken (EU ROM: Beschränken) wird Gmail als Systemapp aufgeführt, bei mir sogar 2x. Aber nur dort. Unter Einstellungen - Systemapps findet man nichts.
Ich werde aber wohl eh auf die Xiaomi.eu ROM wechseln.
Habe gerade gesehen, dass 3 Mail Apps auf dem Gerät vorinstalliert sind:
Gmail
Outlook
WPS E-Mail
WPS E-Mail nennt sich nur "E-Mail", man geht also davon aus, dass es die Email App von Miui ist.
Das Ganze ist nicht gerade vertrauenserweckend für eine Hersteller-ROM.
uniunitracking
